Yes yes, i know. I'll get a hvac load calc , but just looking for guesstamits!
1950s ranch, 1000 sq ft main level, and basement that is getting finished which is 85% Below Grade.
OLD single pane wooden windows, MAYBE an r-11 in the walls ( 2" thick or so....if that " maybe 3" of insulation in the attic that is falling apart.
Summer temps can reach 100+ degrees, typically in the 80s-90s all summer long here in central NJ, humidty can get very very high.
I had a buddy reccomend to me that I go with a 3 ton unit? Though... Alot of the " rule of thumbs " i see are 500 sq ft per ton.... so that works out as:
2 tons per main level
go half a ton for the basement since below grade ?
or
give the basement 1 ton?
Should i just assume 3 ton to be safe with my old ineffectient drafty home?
THanks
or
THanks
