I've poured my footing, and a small "pier block" on top of it. The footing is 2'x2'x12" and the pier block on top of it is 10" x 10" x 10".
If this point is supporting a point on a 4x10 beam that is holding up the center bearing point of the exterior 2nd floor wall, what amount of time should I let the concrete cure before I put that load onto it?
Thanks in advance
Edit : I'm wondering if when I put my post in if I should make it a little longer to account for compression when the weight drops onto it? If so, how much longer?
Thanks in advance
