The short version is I got a couple quotes on adding a disconnect. I just want a disconnect installed after the meter. The existing panel doesn't have to be tied back in as I'll be relocating it. I'm getting quotes of 2-3.5k. How long does a job like this actually take?
I'm a plumber and I know labor rates are high here. I could swallow $200/hr plus material and markup. From what I'm thinking this is 2-4 hours and $200-$300 in material. I'm sure I could do it in 4 if I was willing to move wires around in the meter pan. Am I missing something here that makes it more difficult? I was expecting $600-$1200.
I'm renovating a space over my detached garage. It has it's own 100 amp electrical service. Currently the panel inside is in a kitchen cabinet and is nearly inaccessible I want to move the panel to an interior wall and put in a larger panel. As a result I will have about 16' of wire in the house before it gets to the main breaker.
I'd like to add an outdoor fused service disconnect right after the meter before the cable goes into the structure. I'm going to be doing most of the work myself but working in the meter pan with live unfused connections is something I'll let an electrician handle. I want someone to add a disconnect and connect the line side. I'll install the new panel inside and all the branch circuits then either connect the panel to the disconnect or have the electrician come back and do the connection between the panel and disconnect.
