Everything was working fine and I had both hot and cold water but I plan on replacing an outdated vanity in the 1st floor guest bathroom with a new pedestal sink so I went under the vanity and shut off the old hot and cold water valves. They were a little tight and took a while to shut off but after working them back and forth by hand, I shut them off. I went outside and shut off the main at the house, came back in and removed the old water lines under the sink from both valves that I shut off.
No leaks, no problems...
Everything is back together, both valves under vanity and main are turned on and I get NO WATER (hot or cold), NOTHING, NADA coming out of the sink but it DOES drip occasionally.
How is this even possible?
