I'm building a bathroom in my basement. Started with a builder installed rough-in, pipes run under the slab to the ejector pit. The pipes were all capped and glued when I started, so presumably there shouldn't be anything in them.
I installed the ejector pump and plumbing, and it is working perfectly. Installed the bathtub yesterday. It does drain, it just doesn't drain as fast as it fills. (1/2" pex in to the valve, roughly 50psi on the main line) Googling this only turns up solutions on clearing clogged drains, when you know it is draining slower than it was before. But this is my first experience with a basement bathtub. All of my other tubs here and in previous houses were on the second floor, with a long vertical drop. So I don't have a point of reference on what this one should be.
Am I just expecting too much from what I assume is a 1/4" per foot slope to the pit? Is there a guideline for drain speed, or a test I can perform to find out if it is draining like it should?
