1 - 15 of 15 Posts
I am trying to help an old neighbor lady stop a leak coming out of her faucet. I confirmed it is the hot water side, but I cannot for the life of me figure out how to take the handle off.
I thank you plumbing experts in advance for any assistance with this. There should be pictures below. Thank you.
I can't find any screw.
· GC/Master Plumber/Mech
Looking at the photos there looks to be a seam about 1/8" down from the top of the handle. The top probable comes off to access the screw that holds the hanlde to the stem
There is no seam on that handle; it is solid but I will definitely double check it.
Also, I did look underneath the sink, but perhaps this thing was just designed wrong.
I was hoping to buy a $1 washer for the lady, not a whole new faucet assembly for $100-200.
I tried unscrewing it. Plumbing store had no idea when I showed the pictures.
I have replaced faucets before quite a bit... never seen something so hard for me to figure out. I guess I will just have to remove the whole handle assembly from underneath the sink, and the old lady may end up buying a whole new assembly, unfortunately.
It just doesn't make any sense that once a washer wears out, the whole assembly needs to be replaced, but I have seen crazier things.
Shoot, I am a licensed GC with a lot of strength in electrical, but not much plumbing; not my strength. My plumber is coming in tomorrow morning on a remodel and maybe he might know.
Thanks for your suggestions.
· Plumbing Contractor
Not sure if this will work but try unscrewing the escuchin under the handle. I installed a Moen faucet last week that was designed this way. No handle screws....just the escuchin that held the handle on to the stem.
Discussion Starter · #8 ·
Dudes, thanks for all the advice.
I can't get back there until Wednesday or Thursday evening, since I am working 'sunrise to sunset' right now on stuff.
I will post what I find. I will try turning the bottome escuchian(spelling?) and pulling the handle off.
I showed the pictures to my plumber today at a small remodel we are doing on a 120 year old mansion here in San Francisco, and he said there had to be a screw there; no screw...
My partner says that it may have been designed to be replaced when the washers wear out.
It is just an interesting thing for me to come across; always like to learn stuff.
I will post my findings in a few days. Thanks.
It does appear that there is a seam about 1/8 down from the top. But before you use a tool to pry the seam opened, use a mirror and look behind the handle for a set screw. If you have to use a tool to pry it opened, the only one I can think of is a tiny screwdriver.
Work slowly as I think you may also scratch the handle.
Discussion Starter · #10 ·
Well, I just went over and fixed the leaking faucet. Thanks for all the recommendations. :thumbup:
Anyways, there is no small set screw, since the faucet handle is solid. So I pulled up hard, and the handle popped right off. :laughing: There is no screw designed to hold it on; it just sits on top.
The eschucheon (spelling?) unscrews if needed to replace the assembly, but I didn't need to do that.
However I did need to replace the corroded faucet stem, but I was surprised nothing was designed to hold the handle on. It works fine though.
Thanks again! :yes:
1 - 15 of 15 Posts
