14/2 from the panel to the first 2 gang box.
14/3 from the first 3 way to the 3 gang box.
two of them are travellers and one is a neutral.
14/3 from the second 3 way switch to the 2 gang box.
two of them are travellers and one is a hot.
That hot in the 3 gang will feed the single pole switch and nothing more.
The first two 3 way switches in the first two gang box are fed hot as well.
The second 3 way switches in the 3 gang box will be the switch leg side.
switchlegs go from the second 3 way switches to the lights.
neutrals also go to the lights.
Travellers go between 3 way switches.
This is very vague and there are other ways to wire this. Let me know if you need more.
