1 - 13 of 13 Posts
as you can see in the picture i have a very old aluminum awning that i want to tear down along with the rusting rails and rotting stairs. how would i go about decking over the existing concrete and maybe extending out several feet to make a wood deck with steps down?
Thanks!!
· AfterDinnerDIY.com
It appears that your existing patio is concrete?
The thing you need to be careful about is the distance between the top of the concrete and the bottom of your door. Putting decking on top of the concrete could interfere with the operation of the door. This, to me, appears to be the controling factor for your decking situation and will determine just how hard it will be to deck.
Does the concrete have a slope away from the house?
The hard part is how to deck the concrete, as any part of the deck extendng past the patio can be done with traditional posts and beams.
-Dan
You have a few issue in this conversion.
1. The concrete by the door is too high to put framing.
-You might be able to screw decking to the concrete if the door isn't too low, but that's a half assed way to do it.
2. If you're extending the deck to the left, the ledger board will cover the windows.
i was thinking about doing that but wouldnt it look wierd to have that small bit of concrete before the deck?
Unless you're going to remove the concrete top, there's not much choice. To get a closer match in color, you could stain the concrete to match the wood.
· In a little over my head
First, I'd carefully measure the height of the door threshold. 5/4 deck boards are 1" thick. You may be able to build your deck out from the existing porch, as said above. But make it 1" higher than the porch. Then lay deck boards on the porch, screw or glue 'em down. Maybe even do a wooden frame around the porch to secure the boards to. The boards on concrete may not last as long as the freestanding deck, due to trapped moisture, so design it so they can be easily replaced.
How about getting rid of the awning which will get rid of the metal posts and rail from the concrete area. Then build your deck so the surface is at the bottom of the concrete slab giving you a small step up all around your currennt porch(or you could make it a 7" step). Then build a cover to go with the deck.
1 - 13 of 13 Posts
