I've been in a merciless battle trying to finish some drywall in my home. I had to cut out some old water damaged drywall and install new stuff. I used paper tape on my drywall. I started with a generous amount of mud but now realize that I likely squeezed too much out when embedding the tape. I got a few areas that were blistered. I cut them out and re-applied blue-lid USG joint compound. After sanding and having what appeared to be a decent finish I primed and was hoping I'd be ready for a top coat. To my horror some new blistering showed up. This was only after applying the primer.
So now I'm wondering what I need to do now? Do I go back and cut the blisters out like I did previously and then re-prime? I'm worried that even if I prime I'll be able to see the new fixed area when light is bounced off of it. I planned on using a flat or eggshell finish paint to help hide some of my marginal drywall finishing work. But in the meantime how do I deal with blisters that are under primer? Thanks.
