1 - 20 of 22 Posts
I recently purchased a home that was "professionally" painted over 7 years ago. All of the door hinges were sprayed as they painted. The screws are coated with paint so I cant get the bit in there. How do I remove the paint from top of screws so that I can remove the hinges? I have over a dozen doors with this problem. Any tips you have for the most efficient methods would be great appreciated.
thanks!
· Premium Member
It would be nice if you could remove them......then you can soak them in HOT water and the paint just falls off. Maybe take a screwdriver, put it in the screw slots, and pound them with the hammer just to get some bite so you can take them out. You don't even have to take them all the way out.......you could use some goof off or oops to remove the paint. However, in the end it may be just as easy to remove the screws and replace them with new. Just a thought.
· Experienced
Hello and Welcome Msfrmtx, to the best darn DIY'r site on the web.
As suggested insert screw driver in the apparent slot, tap the driver to seat in screw head and then remove, I would be looking at replacing the screws as opposed to trying to remove years of paint build up.
Mark
· Rubbin walls since'79
If you do get them off, throw them in a coffee can ( metal) with some stripper for a couple of hours, put on rubber gloves and use an old toothbrush to clean off. Wipe and wash clean.
Even screws are pretty easy this way.
· the Musigician
If they were that old and ugly replace them, yup. But the problem was removing the screws with all the hardened paint in them.
I recycle everything, including used screws, so I'd dig the paint out. *grin*
DM
Discussion Starter · #9 ·
thanks for the suggestions. I am willing to recyle if they are in decent shpe...but my primary need is to get enough paint off so I can unscrew them and remove the doors from the hinges.
I plan to recyle the hinges once I get the paint off. I.m just aggrevated by the laziness and the amount of extra work they created.
I cd always paint over them again with trim color and call it a day but I really want to take the doors down to paint them.
· Member
Can I ask, why are you removing the hinges to take the doors off to paint? Why don't you just pop the pins out? The first time I took hinges off a door was the last time I took hinges off a door. There were shims behind the hinges, some of the thread holes were compromised and, though it went back up, it was a nightmare and it was never as it was. I had to remove the door and one of the pins was frozen, so I thought just remove it from the hinges, yeah.
removing hinge screws that have been painted
I want to use my current hardware on the cabinet doors after I re-paint them. I cannot unscrew the screws to remove the hardware due to too much paint on all the metal parts. If I can get them off the doors, I can soak off the paint from the screws, the metal plates, and the hinges.
· Bombastic Idiot
Slotted screws; use a thin bladed screw driver to scrape the paint out, proper size tapped a few times to seat it then lean into it to remove screws. Philips; # 1 tapped a few times on paint then #2 tapped a few times and lean into that. You might need to cut thru the paint around the hinges with a utility knife ,which, with a nod to Danny, you can also use on the screws heads , before you take them out they mite be "glued" in and the paint can chip if you just yank them off. Some paint removers and boiling water can oxidize some metals and remove plating so be carefull.
Tool people see your problem as an excuse to buy a Dremel tool with wire wheels, brushes and maybe even some cut off wheels.
Reactions: debbiekellaway
Can you give me more detail on the stripper to use?
I am not experienced, and when you say "stripper" I do not know what to look for at Home Depot. Thanks!
· Bombastic Idiot
debbie, before buying paint remover (stripper) boil the metal parts in baking soda and water for a while. Then pour the water out thru a strainer and dump parts into plastic or metal bowl of ice. a lot of paint will just pop off from shock. Rest should be soft enough to scrub off. I think I said some strippers will remove thin plating that some hinges have, one of the orange oil strippers might be better, and its easier on hands. Smells good too. I am constantly being amazed at how well that stuff works. Just put some in metal bucket or can and dump in parts, stir, let sit, then wash off with water. dry parts to prevent rust.
· Jack of all Trades
Say hello to my little friend!
Behold the automatic center punch. First shot always breaks through the paint all the way to the metal and usually chips off a good amount of it. It also works great for accurately setting the location where u plan to drill a hole whether it be wood or metal. No more mis-drilled holes cuz of your bit having a mind of its own and moving slightly.
If they are straight slot screws I just use the corner of a small screwdriver and tap it with hammer. If they are phillips you have to pick the paint out or place phillips screwdriver in and whack with hammer. This also helps loosen the screw. I always heard that if they are brass screws stripper can turn them black, don"t know for a fact. If any of the holes are stripped and generally some are the simple fix is a golf tee or a dowel rod in the hole then cut off. Gives the screw some bite. Good Luck
:smile:
I know this is old but thank you. I have 7 doors to do and had started to clean screw heads of paint but thought there must be a better way - yours is it. Took a few minutes to find the right size punch & voila.
It seems as if the original question often gets lost.
The original question was: OP Quote: The screws are coated with paint so I cant get the bit in there. How do I remove the paint from top of screws so that I can remove the hinges?
1 - 20 of 22 Posts
