I'm attempting to remove a bathroom faucet, but I can't figure out how to remove part of the handle from the valve. The valve has the water line connection that exits out the side which makes it to large to lift straight up and out of the hole.
I assumed the chrome part screwed on, but if I hold the valve under the sink I can spin the chrome part independent from the brass part. While turning, it doesn't loosen or tighten, it just spins around and does nothing. I've also tried pulling up to see if it will pop off, but no luck.
I could cut it off, but I have the same faucet I'm wanting to move from another location to this sink, so I need to figure out how to remove it without damaging it.
Is it possible the brass piece under the counter with the two water line connections has to be unscrewed from the top part?
