Here is the issue. Due to lack of knowledge:huh:, a hole 2 1/2" in diameter was drilled through what I now know to be load-bearing. It is in the doorway to the living room from the foyer and there are 3 studs together. Should I remove the drywall on either side of the doorway and attach a full lenght stud with glue and nails to each to reinforce? Any other options like steel plates etc.
This is on the main floor. There is a basement and an upstairs. Was originally drilling to run wires for to allow home theatre equipment to be placed in a closet.
Need some advice. Thanks in advance!
