Hi all,
I have few questions while I tried to install under cabinet lighting.
OK, please check the pictures.
I tried to drill a hole on a finish kitchen backsplash and fish a cable to the power box. However, how do I drill a BIG hole without breaking the backsplash? Also, there are insulation inside the wall which is hard to fish the cable even there are only 7" from the hole to the power box. I tried to remove the power box, but the builder used glue to install it. What should I do? any suggestion?
The worse case is I have to break few backsplash in order to install the power cable, what is the best way to break the backsplash to minimize the damage? Also, after I install the cable, how to I put back the drywall?
Thanks for all the suggestion.
Dan
Dan
