Below is a drawing of my setup to the best of my abilities. I have a gas fired boiler for hot water baseboard on the first floor of my rancher and the finished portion of my basement. As the setup is now, the first floor thermostat is tied directly into the boiler and works fine. The basement thermostat only activates the circulator for the basement, it doesn't turn the furnace on. How can I change my setup so the basement thermostat also turns on the boiler like upstairs does? Right now I don't really get heat on the basement circuit unless upstairs has gotten cold for some reason and causes the boiler to run for awhile. Once upstairs gets up to temperature, the basement will stop heating. If it makes any difference, there is a slight chance I would like to add a 3rd zone in the future. We have a nice sunroom on the back of the house that has no heat and I've considered adding it in the future. The way the basement is setup, it would be very easy to run the piping for. I can provide additional pictures of any parts of the setup you might want to see.
