I used an oil based window glazing (dap33) to glaze some replacement casement window panes (metal sash). Here's a pic of the window:
It has been 3 weeks and the glazing has hardened (somewhat) but there is still a cloudy oily film/residue on the window from when I applied the glazing. It doesn't show well in the pic. Also there are little bits/crumbs where the glazing meets the glass as you can see in the pic.
This is my first time glazing and I would like to know how I can clean the area to prep for painting. I've read that I'm supposed to paint the glazing but go onto the glass just a little bit to actually "seal" the glazing. I want to make sure the glass surface has no residue.
So what should I use to clean the glazing film from the glass and is there a good applicator that I can use to get up close to where the glazing meets the glass? I've read that denatured alcohol can be used to clean glass but I don't know if it's good for this purpose. I certainly don't want to use something that's going to get wicked under the glazing and separate it from the glass.
If these questions seem elementary or not well asked then sorry, I've googled but couldn't find much on the glazing paint prep process and as I said this is my first time glazing. Thanks
