I am building shelves in my basement on concrete walls. I am using metal studs to hold my wood cross pieces for my shelving. My question is, what ways can I attach the metal studs to the concrete walls? Can I drive bolts through the studs into the wall? If so, is there an easy, effective way of doing this? I know that there is single shot tools that can be used but I don't have one and didn't want to get one for a one time use. Thanks for the advice?
Confusing, why metal studs and not wood?
Metals going to rust out if in direct contact with the concrete.
I would go with Tapcons and as Joe said you don't want metal studs in direct contact with concrete.If you do use metal you can buy a roll of sill sealer to back the metal or use a strip of 3o# roofing felt.There are Ramsets (powder accuated fasteners) that are not fancy and set off by a blow from a hammer for around $26 at HD.
Tapcons can be bought in a package with the correct size bit for the screws but you should have a hammer drill to drill the holes for them.
