This is a Thermatru outswing door. I tried following the installation instructions, but I can't get it just right. I have the inactive side plumb on the face and sides of jamb. The door is perfectly plumb. I then moved to the active door to plumb it. If I plumb the active door, it moves the top jamb out of place. The bottom of the active door will hit first. If I try to get the top jamb aligned with the inactive door. It throws the active door out of plumb.
I've checked for square and even tried the cross string test to check plane. I just can't get it lined up perfect without one of the doors being out of plumb.
Any suggestions?
Any suggestions?
