You can sand the finish. You can powerwash the finish off You can remove the finish with chemicals.
You can do a little of each, as needed.
Ron
You can sand the finish. You can powerwash the finish off You can remove the finish with chemicals.Hey.
So we have a deck outside and I want to re-paint it with a semi-transparent or a clear finish stain. But the problem is, is that it's a little rough, and it was previously painted with a paint, and the top is pealing. The bars around it are also painted but the floor is not. (It's sort of a light coffee paint).
So I'm wondering whats the best way to do this? Should I do some sanding, and just paint the stains over the current paint?
