1 - 20 of 25 Posts
Any suggestions as to the most effecient and economical way to heat/cool a basement?
I was going with the pellet stove/ AC approach but wanted to find out if there were any other set ups.
Any feedback on the Japanese heating/cooling consoles?
Thanks.
Hvac Pro
I just took a course on the Fujitsu mini split units. They make them in heat pumps also. They are incredibly high tech and efficient. 19 SEER and higher. Use a ECM modulating variable speed compressor which is very efficient and a bunch of other cool techniques. Probably a bit pricey to install but will save lots of elec $$ in the long run. Quite reliable as they sell them in Russia where the power is bad.
http://www.fujitsugeneral.com/
What would cost look like? Ive looked online and found the units running around 1.5K to 2K. I thought the installation was pretty straight forward. You install wall unit near the ceiling, run a line outdoors and you set the compressor/pump outside on a flat surface.
Is there something that I am missing? Im not experienced in installation by any means but the info online made it seem simple.
ANy other alternatives?
Thanks.
Hvac Pro
Simple? Unfortunately not if you want the unit too last and work PROPERLY. There are minimum pipe lengths and procedures to follow for charging it up etc. Proper wiring techniques etc etc. Just like loading computer software "the devil is in the details". They are VERY efficient units and well built from what I have seen. I am not selling them yet so don't know the cost. They can do some amazing things with that variable speed compressor which no one else can. Better humidity control and longer cycles. I would never recommend those for DIYers or inexperienced techs. Someone who has installed lots of them would be recommended. Those are the Lexus units and in an area with high $$ elec costs will be well worth it.
Discussion Starter · #6 ·
Sounds like sound advice. lol. I dont plan on installing myself. I was just stating how easy they make it look for installation. Im doing the everything except the electrical portion, this would include the heat/cool unit.
Does anyone know the formula for figuring out the correct size?
HVAC / Plumbing
I have not installed or sold any . I have taken some classes on the LG brand.......According to some (I don't know that to b true) that is the future of heating / cooling & that's about all you see in europe. I've never been there so I don't know... The LG brand have some fancy diffusers That you hang on the wall & put pictures in.
Hvac Pro
Correct size needs a heat load calc:Load Calculator
Fujitsu is HUGE, they own Siemens in Germany and have 1/2 to 3/4 the Asian market. Singapore and all those humid places/condos etc must love these units.
Administrator
How big is the basement.
is the heating system for the rest of the house in the basement also.
Hvac Pro
Further to Beentheres path: is the basement finished, ducts accessible. You may be able to buy a high efficiency furnace and A/C and put in a zoning system but it is not a DIY project and is pricey like everything else. Lennox.com. G61V furnace and Harmony III zoning system.
http://www.lennox.com/products/overview.asp?model=Harmony%20III
Discussion Starter · #14 ·
The basement is roughly 500 sq ft. The boiler is in the basement but since it works on steam and gravity I dont think I can tap into that for heating purposes. Everything has been striped down. I have small casement windows that have an opening of 14 in.
I plan on setting up an 9x5 full bath and the rest will be used as a family room. I will partition the laundry area and the boiler/water heater area behind a wall in order to keep that area open for easy access to plumping and sewage lines.
Hvac Pro
I think your best bet is a mini split heat pump professionally installed by a reputable contractor who has done at least 2 dozen of them. You can have 2 air handler/fan units if necessary. The Fujitsu is probably the most energy efficient but is the most complicated. LG, Samsung etc are all good units as they sell hordes of them in Europe/Asia so they have a track record. Does it get hot enough in the basement to need A/C? If it is just humid then a large capacity de-humidifier and some circ fans may do the trick.
Administrator
A mini only is fine.
Unless your outdoor temps drop below what they can provide heat at.
If thats the case, then also add some baseboard for those times.
Or, have a water loop ran off the steam boiler.
Yes, that can and in done, with no problems, if the right guy does it.
Discussion Starter · #18 ·
Beenthere, how do you set up a loop from the boiler?
As far as cooling the basement...when it was a fnished basement (old wood paneling, 3/4 of the room set up, thin carpet on the floor) it was a bit cool and humid. Now that I gutted the place it is still cool but dry. I can only imagine that once I finish the place the humidity issue will return. Also, the coolness during the summer is not the same as the feeling of an air conditioned place. I would much rather the A/C environment. Especially with 3 kids.
Administrator
Need add a aquastat to bring on the boiler, and prevent it from making steam.
You tap your water lop lines in one at/near the bottom, and the other near the top, but not that it would be above the water line.
The supply out needs a Y strainer, and you must pipe up a tempering loop.
Its easier to do, then to explain.
Here is a description and a pic.
Although this one is for an indirect water heater. It done the same for a baseboard heating loop.
Hvac Pro
Leo : How much time do you intend to spend down there in the Winter/Summer and where do you live? 500 sq ft is not a huge area and if your electricity costs are reasonable and you have panel space I would look into some 1500watt or larger hardwired baseboard heaters. That way you can have individual control (wall tstats) and only turn them on when the area is being used. May be quite expensive to add a loop to the boiler etc. Need radiators, pump, controls etc. Do you have A/C upstairs and how is it done. Also a couple of portable A/C,s vented to the outside may help. See:http://www.cleaning-guide.com/portable-air-conditioner.html
1 - 20 of 25 Posts
