1 - 13 of 13 Posts
Hello everyone long time reader new member. I am looking at buying this home. Double wide on crawlspace. I am familiar with foundations in general but this one is odd. Blocks pushed out of wall by themselves cracks in all four corners. I have never seen individual blocks pushed out of wall before with rest of wall basically intact. Anyone encountered this before. Any insight greatly appreciated.
Thanks for the reply. I went into the crawlspace and checked walls with a level. Nothing in depth but a general level check and all walls close to dead on. Double wide on foundation have what looks to be a larger I beam structure than tie down ones I have seen. Thought I beam structure might have shifted or foundation shift but did not line up with block dislocation.
· Retired Moderator
Must be water getting in the webs and freezing
That is what I thought or maybe they popped a block out to get to something, but you said it was ok from inside, it has to be water freezing then, that is all I can think of.
Out here perimeter mobile home foundations, usually CMU's, are not structural.
Unit is self supporting with no perimeter support.
As you saw there are tie downs in place and usually two strips of concrete poured to set piers on.
Discussion Starter · #10 ·
I know there are some soil issues evidenced by the other pics below. Inside the building all doors and windows open as the should. Unfortunately because the walls are boards and not drywall cannot find clear evidence of cracking.
Look for problems in the structure above that area, like the siding maybe, that could lead to water leaking into the blocks. Also at the point where the structure sits on the block. Is there flashing on the siding or whatever is above the block, that extends below where the block begins, so water can't just roll off the wood and into the block?
1 - 13 of 13 Posts
