If you have an electric water heater, it will most likely be 240Vac. You can switch either one leg or both legs...but the one you want to use is the one that looks just like what is already in there. In most cases you should be able to get the right part based on the model # of the water heater.
But, before you go doing that, what makes you think it's the thermostat? If you water is not hot enough to begin with, that could be the t-stat....but running out? Likely one of three things....your dip tub may have fallen off, one of your electricl elements is bad (water still gets hot but takes longer) or your kids are using too much hot water.
I would look at your elements first. Best way to know is to measure the amps. Your water heater has a posted wattage. Convert that to amps....use a clamp on amp probe to measure the amps going in one leg of your 240Vac. If your within 10-15% of that value, your heaters are ok...
