I contracted to have our local builder add another bedroom onto our house which I wanted 16 X 16. Our contract doesn't include a floor plan and says "to build one 16 X 16 foot addition onto existing home according to plans furnished by the contractor and approved by the owner" and then details materials, finish, etc.
After the footings were poured, I measured and the room size would end up about 14 1/2 X 14 1/2 feet inside wall to inside wall. The builder said he has done it correctly because room sizes are always figured outside wall to outside outside wall.
Is builder right?
As everyone else has said, the contractor
seems to have given you a 16' x 16' room addition according to the footing measurements. But I'm wondering if he really did. Does it appear that way to you when you put a tape on the footing? I ask because you seem to say you are losing almost a full two feet in either direction. Even using concrete blocks, that seems like a lot.
First thing I would do is go re-measure for where the 16' dimension would fall. If that is on the outer edge (or even outside) the footing, you aren't going to end up with 16' outside.
And he should NOT be calling the edge of the roof the 16' dimension. It's the outside edge of the structure.
And one more point. Your post says two different things.
This seems to indicate that if you never received... AND approved... "plans furnished by the contractor", there is a contractual problem.
I think you would both be in the wrong here. Him for not delivering plans for approval, and you for allowing a start without seeing any plans. Catch it now. Work out an agreement on what he will see as 64 more square feet. That's a fair amount of money... Probably $10,000 or better.
But get this worked out right now.
And grab hold of the responsibility that is yours too. This is your home, your money, and you had danged well better know (with no uncertainties) exactly what your are getting for the outlay.
"I thought............. " flat don't cut it!!!! That's exactly WHY contracts are the standard.
