I am rewiring several rooms in my house do to a need for more receptacles in certain rooms and just a general need to organize the chaos that is how they wired everything. Lights and plugs together spanning multiple rooms, etc. To that end, I have a few questions regarding the NEC to ensure I have all of my facts straight. Most are hopefully simply "yes" or "correct" responses (hopefully)...
1. To separate the first floor lights onto new circuits from the wall receptacles, I am bringing 2 new 14/2 romex cables from the panel (which is in the basement) into the attic. The easiest path for these is to follow a drain pipe that stretches from the attic to the basement. Is it ok to follow this pipe with the romex?
2. I intend on adding some lighting in the attic. Are there any special rules for attic lighting and cabling? Such as...
A. Do lights in the attic require GFCI protection?
B. Is there a problem using the same circuit that serves the lighting on the first floor?
C. Can romex be staples to the bottom of the rafters to string the romex from rafter to rafter across the attic?
3. 99% sure on this one but since I am posting figured I'd double check...Receptacles in the bathroom need to be GFCI protected, but this DOES NOT need to be at the breaker level. If the first receptacle in the bathroom that ties back to the panel is a GFCI receptacle, a standard breaker can be used in the box correct?
4. A big question where I have some uncertainty...I am planning to cut out the drywall all around the perimeter of one room to add additional outlets (currently only 1 per wall and current code would require 2/3 per wall) to the room and "upgrade" to a 20 amp circuit with 12/2 romex. What are the rules/guidelines for running the cable through the studs, box to box? 2 of the walls are exterior walls, 1 is a load bearing, and 1 is a non-loading bearing in case the rules differ based on the load, etc. I read an ehow article that was just like drill a 1 inch hole in the studs and run your wire, but that seems a little fishy to me to drill a 1 inch hole in a 1.5 inch board. I know the guidelines for joists/headers is no drilling in the middle third of the span, 2 inches from either end of the board, hole no larger than 1/3 the width of the board. However, this doesn't seem to be possible with studs and I know new construction is wired box to box through the studs, so I am trying to figure out what the rules are for it.
Thanks again for all of your help.
