Hey, I'm getting a new modem for my internet service soon and I want to make sure that there's no grounding issues for the outlet that it will be plugged into.
Unfortunately, the area it needs to be is an old two prong outlet. As of now I have a spike-strip extension cord with a red light 'line fault' I'm assuming that means grounding issue. So I have a couple questions.
If I use an adapter (the ones that plug into bottom or top, provide three extra places to plug in) and put a screw through the little ground flap into the outlet plate, will that ground it and prevent dirty power?
If I buy the whole replacement at a hardware store (box, plate, etc..) three prong, will it be grounded correctly, or does something else determine that?
Do I have any other options to get this area grounded correctly. My main thing is I don't want dirty power going into the modem.
Thanks in advance!
Thanks in advance!
