1 - 12 of 12 Posts
Ok. Hall light on three way. Getting 50v when switched off. Put the tester from hot to neutral, 50v. Open neutral, right? But the hot/ switch leg also says 50v when I go hot/switch leg to the pipe/box. That's not open neutral, right. Must be something with the travellers, right? It's been awhile, hello all DIY'ers. :)
Tom
Probably phantom voltage particularly if you are using a digital meter. When you connected a 15 watt or larger incandescent lamp across the meter probes at the time of measuring, what voltage do you get?
Electrical Contractor
Burned out bulb. Try it again with a good bulb installed.
Discussion Starter #4
No, it's an analog tester. 50v every time. The problem wouldn't have even been noticed until my friend replaced hid incandescant bulbs with led's. The suchers blink like runway lights when the power is off! LOL. I'm gonna look at the three way switches and double check them, but I doublechecked them before when I installed them. ???
Tom
Tom
Incandescent lamps/bulbs are not HID lighting.
Get rid of the lighted wall switch then. Those don't work well with LED bulbs.
JOATMON
Your seeing induced voltage....caused by the wires traveling next to other wires that are hot.
I suspect the LED lights are blinking because the voltage is enough to charge up the voltage ckt to a point to where it fires the LED...
Two solutions....
1. Chase down the wiring...seperate it from any other energized wiring....especially if it travels next to it for a long distance.
2. Install a small load on it...say an incandescent night light? Or, just replace one of the LED lights with an incandescent bulb.
On a side note....I wouldn't swap out that lighted switch just yet....I can't see why they would not work well with an LED light.
The little lamp in an illuminated switch is in series with the "main" lamp being controlled by that switch. When the switch is in the on position the switch contacts cause the current to bypass the switch lamp and go through the main lamp only.
Illuminated switches are based on the current draw (amperes) for the switch lamp being much smaller than the current draw of the "main" lamp so the main lamp does not light up. When the switch is flipped on, the switch lamp is out of the picture and the current draw in the circuit is governed by the main lamp only and of a greater amperage. LEDs and some compact fluorescents may themselves consume such a small number of amperes that they come to life with the amount of current that the switch lamp draws.
1 - 12 of 12 Posts
