The relief valve is leaking. I changed the relief valve and the new one is still leaking, Now i read that maybe i should put an expansion tank on the cold line but this line has never had a expansion tank on it and why would i need one now? Just don't want to have an expense if its not necessary. Question, would a bad Tank cause it to leak? And i don't think the temperture is to high ,cause the water is not getting too hot ,cause you can keep your hand under it without it burning you. And the pressure in the house doesn't seem very High coming out of the Faucets. In fact ,seems like it use higher pressure, I got a feeling that the line maybe partialy clogged some where as the lines were worked on about 8 months ago. But would that cause the T&P valve to Leak? Thanks
