Is there anyway to fix this leak without digging up the cement? Could I possibly go through the ceiling and back over to the connection that comes out of the wall where the pipes come out under the sink? I know I have a hot water leak because I can feel a hotspot on the tile and there is no other explaination for it. The water meter is also moving indicating a slow leak and the water bill has been higher than usual. Any suggestion or help would be appreciated.
Repair of leaking pipes.
http://CURAFLO.COM Hello
My company is Central/Northern Ca Pipe Lining Inc.
We coat the inside of "potable" water pipes, i.e. galvenized, copper or steel, with NSF 61 Certified epoxy. It is made to last 50 years and will not rust, corrode or peel. After it is applied, water may be returned to service after five (5) hours. It will fix PINHOLE leaks.
We coat the entire structure i.e. homes, condominiums, hotels, motels, hospitals etc, as once the leaks start, they will continue throughout the entire structure.
It is usually 20-30% cheaper than repiping and we give a 10 year warranty on parts and labor.
If I may be of help, please call:
Stan 805 674-8381
