I have an 80 gallon hot water heater that is dripping from the pressure relief valve.not much, not even a pint in a few days, I was told to shut the power off (its electric) shut off the feed drain some water from the tank and then try releasing the pressure.
well i shut off the water hooked up a hose to the drain and no water came out i then tried the pressure relief valve and got nothing. am i doing something wrong is it just junk and need to call a plumber? any advice would be appreciated.
