I have searched and searched this, but nothing is coming up that is helping me on this problem.
I am trying to flush my water heater. Its just a typical GE 55 gallon(i think) stand up unit that sits in a closet with my central air unit in the hallway of the house. I have read and reread and watched videos on how to flush it. Seems real easy and i have been a mechanic in the past. So i have a strong mechanically inclined mind.
For some reason, when i open the drain valve at the bottom of the tank, no water comes out. At first i though that maybe it was vacuum locked and needs to be vented at the top of the tank, but this did not help. I next thought that perhaps it is blocked with debris inside the tank at the valve. Pretty likely that is the problem. This thing, im sure, has never been drained. Its not that old of a unit judging by the way it looks, but i have no way to know. Ive lived here for 5 years and it was here.
So i used my air hose from the garage to try and blow some air back into it in hopes that it would maybe clear it out a little bit. I have a commercial grade air comp. that can go to 175+ PSI(this is left over from my mechanic days:thumbsup
. I attempted to shove around 120 PSI into the valve, but it did not help. Still nothing comes out of the drain valve. I gave up trying...
I am left wondering what is the problem, obviously. But i also wonder how important this really is? I just heard from a guy at work about flushing the water heater to keep the debris out of it so it will heat more efficiently and last longer.
Should i be worried that i cant get it flushed? Or should i just ride it out and wait till some day when i replace it and then keep up on the new one?
Sorry for the long post... Thank you for your time!
