1 - 20 of 20 Posts
I've never heard of this before.
Next to the 16 yr old condenser there's a metal box, 12" x 14" and about 3 or 4" deep. Its on the house.
I just learned its a 'hot water heater'. Personally I don't grasp why an AC would heat my hot water when I have a hot watertank.
Don't know if it's been working or not. It's not compatible with my new unit. He said a new water heater (for the AC) would be another $900 which I can't afford.
I've been around a lot of contractors and am surprised I never heard of this before. Are these hot water heaters very unusual or popular?
· In Loving Memory
Its a desuperheater. As known as a heat recovery unit. They can save you a lot on your hot water bill in the summer. They are not a popular as they once were.
They are actually cheaper to use to heat or keep a swimming pool warm the natural gas is. Since all the heat is waste heat that you are paying to get rid of anyway.
Reactions: Startingover
Yes sir, you are correct.. More or less.. pulls the heat off the condenser side of your split system
We use condensing units here to heat outdoor swimming pools in summer here ,, they are water cooled condensers instead of air cooled .Works very well ..... gotta run a/c in summer anyways why not put the energy to good use .. A mfg in montreal mfgs a unit that "dehumidfes/heats the pool water /removes humidity and even reheats the air "on indoor pools and they are very cost effective and work very well
· In Loving Memory
so, are you guys saying that my city water runs thru this "recovery system". (or maybe it did. I don't think this thing works)
They usually had water lines ran from the water heater to it, and it has/had a circ in it that would run when the A/C ran. If the hot gas temp was above 120° the circ would run to heat the water in the water heater, provided the water heaters water temp was not above set temp.
· In Loving Memory
Dectron is who I see around here.
1 - 20 of 20 Posts
