Hey, need big help with this, it's7 degrees, with no heat but a wood stove. I just turned my boiler on last night, it heated up, woke up to no heat. Temps/pressure were normal on boiler, circulator pump was very hot to the touch. I replaced the circulator, still no heat, and it was very hot also after running for 10 minutes or so. I did bleed the system with a bleeder on the second floor, no air and very hot water on the supply side to upstairs, didn't think to see if the return was warm though. The whole house is one zone with a "T" to feed both upstairs and the first floor. I do have two sections of the plumbing that run thru the attic, one about 3' the other about 6' that are uninsulated (I know dumb, not a spring project). Even if these were frozen, why would I still get no heat down stairs where it has always been above 32.
Anyone with ideas, I'd be more than happy to listen to, the wood stove is good but struggling at these temps, mornings are far to cold. Thanks, appreciate any help!
