1 - 7 of 7 Posts
I am in the northern Virginia area and the past few days the temps has been 90-93 degrees.
The upstairs has its own A/C unit which is a Trane XR13 (3 years old) with a York Air handler that sits in the attic. All the airducts go through the attic to the 4 bedrooms.
During the late afternoon/early evening hours the temp of the air blowing out of my air vents is around 70-72 which is making it very warm upstairs. I keep the thermostat around 75 and at 4pm the temp upstairs is reaching 78 with the AC running all the time.
I checked the temp coming out of the vents at 10pm and the temp was 58-60 and finally cooling down the upstairs rooms. The air ducts are the insulated air ducts.
2 years ago I added about 6-7" of blown in attic insulation which hasn't made a bit of difference.
Anyone ran into this problem and able to fix this issue? Any suggestions would be appreciated.
Ash
lowering the temp in the attic would help also. do you have plenty of ventilation in the attic? ridge vents? plenty of soffit vents or even a fan to pull the hot air out and cooler air into the attic? and is the ductwork insulated?
Ash
1.Rinse off the coil with the water hose. 2. Replace the air filter. After all these it should work if not then unit is out of freon.
1 - 7 of 7 Posts
