Hi all,
I have a hot tub that requires a 50-60 amp GFCI power supply. The hot tub is located about 25' from the swimming pool sub-panel. he swimming
pool sub-panel is fed by a 50 amp breaker on the home's main panel. Since the main panel has no open slots and the pool sub-panel is closer, I would like to connect the hot tub to the pool's open slots in the sub-panel. The sub-panel has a 240v 20 amp breaker feeding the pool's pumps and a 110v 15 amp breaker feeding the blower.
I first thought that I would get a Connecticut Electric GFCI Load Center http://www.spadepot.com/shop/Spa-Disconnect-GFCI-Load-Center-240V---30A-to-60A-P9279C193.aspx ,install a 50 amp breaker in the pool's sub-panel, run 4 wire #6 AWG THHN in conduit 3' to the new GFCI Load Center, then run 4 wire #6 AWG THHN in conduit about 25' to the hot tub.
I was just about set on this plan when I re-read the installation instructions for this unit that said that if the unit was equipped with an integrated GFCI (see PDF http://www.hydroquip.com/Owners Manuals/AIR/DELUXE/Electrical_Installation.pdf ). This made me think that I may be able to install a standard 50 amp breaker in the pool's sub-panel and run the 4 wire #6 AWG THHN in conduit about 25' to the hot tub utilizing the integrated GFCI.
So my question(s) is/are this:
Is my original plan ok to add a 50 amp GFCI sub-panel off of the 50 amp pool sub-panel to feed the hot tub?
Would the second thought of no connecticut electric load center work running direct to the control unit with integrated GFCI?
Are both plans off the mark? Are either ok?
What do you suggest?
