Hello everyone. I will be installing a Caldera Cantabria hot tub soon and need to run the electrical from my main panel to the GFCI sub panel. I will be installing a non-GFCI 70A circuit breaker in my 200A main service panel. I will need to run the two hot wires, neutral and ground wires approximately 55-60 feet from my main service panel in the front of my basement to the side and then the back of my basement and then finally outside. I am planning on mounting the Subpanel on the back of the house approximately 1-3 feet after the wires exit the basement to the outdoors. The hot tub will be at least 5 feet away from this, but probably about 6-8 feet away.
I have attached a picture of the wiring diagram provided by the manufacturer. Can I use #6 wires from my main panel to my sub panel like the wiring diagram says? Or does it need to be #4 wire? Also what type of wire should be used for this application? The majority of the run with be indoors in the unfinished basement ceiling area but I will need to run the wire in conduit outside for approximately 1-3 feet.
The sub panel has 2 20A GFCI breakers and then one 30A GFCI breaker. Wiring the 2nd 20A breaker is optional, but required if you wish to use the 3rd dedicated pump for the lounge seat at the same time as the heater. I live in New England so I figured in the winter time the heater will most likely need to run at the same time so I figured it is worth it to wire the 70A option with the 3rd breaker over the 50A option with 2 breakers.
Thank you!
Thank you!
