I was sitting at my desk today and the breaker for the office area tripped.. I turned it on and about an hour later it tripped again.. I noticed when it was on the surge protector and UPS i have both showed ground fault errors. I picked up a outlet tester and it showed Hot and Neutral reversed as the error. I opened up each outlet in the room and not one was reversed (white was on silver, Black on gold). I have been in my attic several times and know which outlet is the main and how it is running throughout the room. I unhooked the main outlet and verified it is getting power on the neutral wire with a contactless voltage tester. I then when to the breaker and noticed that the neutral wire was getting voltage when the breaker was off and not the black wire.. I am not sure if this is supposed to be the right way or not, but I found it odd that this is the case.. Any advice?
Here is a video of me testing the breaker..
If I am doing something wrong please let me know, also could the breaker be causing the issue?
