I tested my water pressure both inside and outside the house, and it's 130 PSI! This can't be right! No wonder my washer kept blowing water lines off their fittings!
Does this mean the water regulator off the main line is bad?
And how worried should I be about this?
By the way, that gauge actually spiked to almost 200 PSI when I first turned on the water. I had manually reset it before taking the pic.
Could the gauge be bad?
