I want to put in electric radiant floor heat mat in my bath remodel under the tile. How do you connect it to the electricty w/o tearing up the walls to access the electric supply?
First you would have to determine the electric load the floor requires. I would recommend that the heating be put on it's own circuit, so in any case you would need to run a new line from the main panel to the bathroom. On the slim chance the instructions don't say that, you will still probably need to open some walls to get the wire where it needs to go.I want to put in electric radiant floor heat mat in my bath remodel under the tile. How do you connect it to the electricty w/o tearing up the walls to access the electric supply?
The more you do, the better you get. Eventually you'll open walls like you open a door.Thanks. well i was afraid that would be the case. we can do it, no problem, i just dislike doing drywall repair! oh well.
