Hi
I am Mike, new here.
I bought a house recently that has a True Steam humidifier by Honeywell.
It does act up from time to time requiring me press reset or call maintenance, but a week ago it developed a leak (slow drip) between the bucket and solenoid valve.
I pulled the bucket out, emptied it, noticed the nipple has theflon tape wrapped around, which means it had problems before as it has its own seal. Also the solenoid valve has some scaling inside that I suspect was breaking the seal. I tried to clean it with Qtips and vinegar but not too good.
Now I called a service given to me in Honeywell by name, I told them what model I had, today they came, gape at it awhile, said they do not install or service these and went away.
So. I know the solenoid valve is $43, and the bucket is $75.
I can easily do it myself but what I do not know if all these tubes, mostly PVC (water feed) and one thick rubber tube (seems to be overflow) need any cement/lube when connected.
And.....do I need the whole bucket or the nipple with seal gaskets is available on its own (did not see it online, seems to be a part of the bucket).
Anyone with experience in these?
The exact model is HM512A1000
Best
Mike
Best
Mike
