I have a Honeywell TH4201D thermostat, with a Rheem heat pump that has two auxiliary electric heat strips.
I'm a little confused about wiring the T-stat.
Pictures of t-stat guide and heat pump guide, are below. Air handler says "jumper W1 and W2 for maximum heat rise".
Questions:
a. Is it correct that W1 and W2 have nothing to do with the outdoor unit - that all the outdoor unit cares about is wire Y (compressor contactor), and either activating or deactivating the reversing valve (in my case, wire B for heat)?
b. Should I jumper W1 to W2 at the air handler, and E to Aux at the thermostat? Based on reading, it seems a lot of techs do this - what exactly does it accomplish?
c. What do I do with wire L from the T-stat? It says "L is powered continually when set to emergency heat". I see no where to wire it, either at the air handler or the outdoor unit.
Thanks in advance for any help you can give me to understand this wiring.
Questions:
