1 - 9 of 9 Posts
Hello, this is my first post here and hoping to get some help. I installed a new thermostat, and it works well, except for one thing that's making me nuts. I have every day of the week programmed for 72 degrees. For some reason, between 9-10pm it's like it reverts to a default or something. It goes to 66-68 degrees and holds that till the morning. It's wired correctly or wouldn't work at all I've read, but it's that night time problem I can't figure out.
I greatly appreciate any help on this!!!!
Thank You,
if that's true and no one is playing a game with you, return the stat if it's not doing what it's supposed to. (be sure that weekends are also programmed, check the programming with a fine tooth comb)
Discussion Starter · #9 ·
Hi and Thanks. Well I called Honeywell, and after being on hold for 20min literally I was able to explain to the guy what was going on. No Joke!!! he actually said..."Well it could be the weather". I have no words for what my brain experienced, and I still am baffled by that. So after another 20min of me asking him to repeat himself I was finally advised that I should take back and get a new one. Again, I have no words, pffft. So I took my HoneyHELL thermostat back, got a different brand and that one seems to be working.
But thanks for the responses!!!
1 - 9 of 9 Posts
