Im using a honeywell hz311 and Im trying to run 2 zones one with 15 dampers the other has 7 dampers. 15 dampers would be the max running at any one time. Each damper needs 0.25 running amps so that times 15= 3.75 amps needed. A 75va transformer "which according to the manual I could use on the hz311" only puts out 3.125 amps. so how would I go about getting enough power to run 15 dampers at once??
PS Im electrical illiterate so please keep any answer simple stupid for me..
Hvac Pro
You could try e-mail Honeywell tech support for the zoning panel.
Should be a address with the manual it came with.
