I'm having to make a homemade dog house for my rather large Akbash mountain dog family (papa, mama and 12 wk old pup). I live in Region 5, western Colorado. I need a floor panel, roof panel, and 4 wall panels.
I had this design for making the panels utilizing empty water bottles. What do you think? Will this work well enough to keep in heat and block outside cold air? I wish I had some idea of the R value.
Cut 42" long x 36" tall 1/2" thick thick plywood panels. Glue 2x4s around inside edge of each wall panel perimeter, on the wide (4") side. Place additinal 2 x 4 down middle of the floor panel (so it won't sink under dog weight).
Place 2 layers 3mil plastic into cavity, draped over the 2 x 4s. Tightly pack 16.9 ounce empty-dry and capped plastic water bottles into the cavity. Pack Styrofoam scraps I have around the empty water bottles. Place another 2 layers of 3mil plastic over the cavity materials and glue and screw the top panel onto the bottom (into the 2 x 4s).
Adhere aluminum foil onto the interior panel surfaces. Paint the outside black. Staple tar paper and plastic onto roof to shed snow and rain.
The empty, air-filled water bottles fit perfectly between the two panel surfaces when compressed slightly.
