I am wiring in my new load center. I got a Homeline 200A main lug with a main breaker, 20 space/40 circuit model (So it's rated to have a dual-breaker in each space if desired.)
What I'm still just a bit confused about is connecting ground and neutral.
The box has two main lugs which are obviously for the hots, and a center lug which looks like it'd be for the neutral.
Once I hook these up, do I just hook my grounding conductors (to ground rods and plumbing/gas pipes) to the neutral bus somewhere?
And for my circuits, same thing? Do I just put the ground and the neutral on the same bus bars?
In other words, since this is my MAIN panel, do I just consider the neutral and ground bus bars the same thing in this panel, when attaching grounding conductors both to earth ground and to circuits?
The box has two bus bars, along each side of the main circuit connectors. It appears visually that these are both connected to the service neutral. There's no separate "grounding" bus bar in this panel. I'm guessing one can be installed, but I'm wondering what's required.
I already know that in a subpanel you need to isolate ground and neutral, and since I am doing a subpanel I'm planning for that, but this is the main service panel, and this is the one aspect of wiring that's always confused me just a bit.
Thanks!
F
Thanks!
F
