Greetings All!
Here's my situation... I'm employed as a 3d graphic artist and my computer setup is massive... well moreso than an average user. On my desk I have a 7 monitor spread working over 4 computers, and that's just at my desk. I mention this because my requirements for an office space go beyond some of the 'stick a piece of wood against a wall and you have a home office' suggestions I have found around the internet.
I am losing the spare bedroom that I had as my office due to the fact that we are having a baby. The only room left to me is the garage. So I started perusing ideas for converting the garage to an office. The problems I'm running into are that that the garage is unfinished, no AC (I live in Florida), and when it rains the edges collect water, which seems to be coming in at the base of the walls.
The idea I came up with was to construct a room on wheels so I can use a small window unit AC and the wheels are so I can move it around if I need to. What I had in mind is essentially a wooden box 8'x8'x7' which will move around the garage and also fit through the door of the garage if I need to roll it outside for any reason. This seems to be my best option because I can insulate it and keep it cool while also keeping the computers safe from the elements. The other idea was to build it as a modular unit, basically 2 4x8 1/2 rooms that will fit together, be it with a few screws or with some kind of heavy duty locking clips.
I had planned on making it light-weight, so the floor would be of 2x4s and plywood, while the walls and ceiling would be 1x3s and paneling.
Of course I could be overlooking some other way to do this... which is why I have come to ask you good people your thoughts or your advice on the best way to do it, maybe some materials that would be inexpensive but sturdier than what I'm planning on using.
So... if you are so inclined, fire away!
Thanks in advance.
Charlie
Thanks in advance.
Charlie
