The drain pipe on the right with the rag in it drains a sink. It is too high coming out of the wall for a lower dual sink bowl/disposer I want to put in. I need to lower that pipe 4-6 inches.
Can a hole saw go through the 4 2X6s you see? Appreciate any recommendations. May need some sort of extension too.
I will need to put another T in below the existing T. Can I use a clamp version versus gluing in a T? I can't really move any of the vertical pipes up or down to glue in a T joint.
In the lower left I removed the threaded cap. What is this for? I believe the pipe goes up and vents to outside through roof. I thought about maybe use the lower threaded connection as the new drain but the trash/recycle cabinet goes there and then the drain pipe would be in the way.
Thank you
Thank you
