27-yr. old Mobile Home Nordyne Package Unit with capillary tube behind a front access panel.
1/4" long x 1/16" wide (if that wide) hole/rub spot? Supply counter tech said braze over it or braze in another piece.
Not sure what caused this, but the capillary tube had to be pushed in some when I was reinstalling access panel, cause it was rubbing against the access panel. Didn't stop to see if the damaged spot of tube matched up to the panel spot. Someone else had inspected this unit some time ago, so don't know if he had pulled the tube outward some for inspection or what.
Can be repaired? My tech/partner hasn't seen it yet, but says brazing over it might be difficult due to brazing material dropping into the hole.
