Hi all,
I have a gas furnace which works OK "most" of the time. However, there are times it will shut off prior to reaching it's target set temperature. I have changed the filter, changed the setting on the thermostat to try to get it to reach the target temperature. And I am not sure why it is inconsistent (sometimes works, sometimes does not). I have had this furnace for less than 1.5 years.
Today, I removed the cover and noticed a build-up of water inside. I am not sure what is causing the water build-up. Anyhow, I am thinking this may be causing my furnace to shut down prior to reaching the set temperature.
Anyone with any ideas on next steps?
