If you didn’t see my other thread, I have a 72x300’ fabric tension building (200’ is the arena). I’m replacing my existing T8 6bulb fluorescent fixtures and the existing 10/3 MC cable (that my ex husband installed) due to storm damage.
The new fixtures will be LED UFOs 150watt (1.25 amp). They are set up in 2 rows (8 fixtures each). The fixture furthest from the service panel (220amp panel with plenty of room) is 272’...
I was toying with the idea of swapping out the 20 amp 120v breakers and putting 8 fixtures (10 amps total) inline on one circuit with 220v (w/15amp double pole breaker?) using 10/3copper wire because it would be a lot cheaper and easier to install but that leaves me wondering...
Using a voltage drop calculator on #10 over 273’ = 2.93% =
213.55v x 15 amps =3203.25 x 80% = 2,562 watts. The 8 light circuit is 1500 watts... is that enough to trip the breaker?
I was asking a industrial HVAC guy about it, and he said he wasn’t sure these lights could be run off 220v....???? The item description says 120-277v but they do have versions of the same fixture with higher wattage options...??? Your thoughts?
I’ve put in a 220v outlet for my welder successfully... but not sure on lights.
