YES. A few cents make big $$$$ - One million Penney's is $10,000.00--- I learned about the piston the hard way! Last summer I installed a new AH -14 SEER- 4.0/ the used condenser at the time was a 3.5 -13 SEER - The piston I used was .076-- yesterday went to install new 4.0 -14 SEER R410A condenser-- did not get a piston with the new condenser- did not have a piston chart with me. I was think 410A piston is smaller than R22-- I guessed at the size- SH & SC low= undercharged-- put some gas in & inside split TD went down. - That is when I realized problem was size of piston. Piston chart calls for .080 - My brain was thinking 13 SEER 3.5 condenser & R22 - and was working on 14 SEER 4.0-R410A-- Lesson learned - when installing 1/2 system buy the correct piston with the unit- don't assume you will get piston with condenser any more.:vs_mad:Anything to shave a few cents off each unit.
YES I agree!! Crazy not to supply a piston!!! The counter guy could have given some heads up??? Your doing job on weekend ,and or supply is 50 min drive. What are you going to do??? Thinking not including a piston is going to cost the mfg more warranty claims!:vs_mad::vs_no_no_no:Have well under 100 compressors fail in warranty because there's liquid flood back in certain conditions and the savings evaporate.
It's crazy to not include a piston - the coils are in nominal tonnage only for 13 seer; a lot of contractors won't buy the piston if a bigger coil is needed to get the efficiency.
It adds what, probably under $1 per unit - just increase the price by a buck for god's sake.
They may do that because the matching Goodman air handler or matching Goodman coil has the piston already.The New Goodman 14 SEER condensers, do NOT come with a piston. Think about it if you are putting in 1/2 system, changing from R22 to R410A or may need a piston match.
You don't automatically get a flare nut when you buy a flare fitting either. You have to buy it separately.Have well under 100 compressors fail in warranty because there's liquid flood back in certain conditions and the savings evaporate.
