I have a screened in proch I have already added outside walls using t1-14 and a front door how much is it going to cost to finnish, I still need to add a sub floor, drywall and remove the skin from the mobile home where the old front door was and on the same wall remove the windows to make a walk through the room sixe is approx 15 x 20, I only have 800.00 left. will that cover costs for materials? someone please help?
· the Musigician
i could pull it off for less, but i shop and find bargains too....
your question is rather vague and there are many variables that would determine prices.
you did not need to post this in so many different rooms.
DM
You should take pictures of this project and bring it to a local lumberyard or big box store and get it priced out.
The details are too vague to help you.
Ron
· Registered User
You may want to check with your local Building Department. You are adding living space to your mobile home.
Things to consider are: light and ventilation, heating and/or cooling, wiring, footing size for the added weight, safety of the structural framing (tie-in), etc.
You could be in a high wind (Florida, etc. area) or a seismic zone (CA, etc.) that address special concerns.
When you go to sell, you may end up tearing it all out. Be safe, G
